Help with adjusting valve lash
Old Mar 6, 2009 | 02:34 PM
19Pontiac88's Avatar
Car: '88 Firebird Formula
Engine: 355 TBI
Axle/Gears: 10 bolt
I probably should know this by now, but which valves are the intake and exhaust on an '87 350? I was so sure the exhaust came first, so I adjusted the lash on the drivers side, but then on the passenger side I got lost. Are they the same, or is it the opposite? Also, what method do you use to adjust valve lash? One book says to watch the lifters, and when one begins to come up, tighten the other and repeat throughout the firing order. Another says to put it at TDC, adjust certain valves, then rotate the crank 360* and adjust the rest.
Old Mar 6, 2009 | 02:52 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Help with adjusting valve lash
Ex-In-In-Ex-Ex-In-In-Ex
Just look at the exhaust manifold and you should be able to tell.
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
dimented24x7
Sep 6, 2015 03:51 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
