A compression ring put a light scratch at top of cylinder?
Old Mar 9, 2009 | 07:54 AM
quick57's Avatar
I installed std pistons with std cast rings in the 350 for my brothers nova. I turned the crank to position the second crank journal at its lowest point to install pistons #3 and #4. I looked into cylinders 1 and 2 and noticed that cylinder #2 had a minor scratch (you can't even get your finger nail to catch on it or feel it). I guess I didn't debur enough edge off one of the compression rings ends. Is this going to cause any big problems?
I don't expect this to be a 100,000 mile engine. It's just for a weekend cruiser. It will see maybe 30,000 miles at the most.
Should I pop the piston back out and file the edge of the ring and reinstall or what?
Old Mar 9, 2009 | 03:04 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: A compression ring put a light scratch at top of cylinder?
A file is probably far too coarse, I'd go with emery paper. And one little scratch at the top isn't a problem. You just don't want to be greating alot of scratches in the middle of the cylinders. That could eat the piston skirts, sending bits of metal all through the engine.
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Omega
Aug 10, 2015 12:46 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
