91 5.7L Z28 Problems
Subscribe
Mar 17, 2009 | 03:26 AM
Hey,
Just bought a 91 5.7L camaro z28, automatic. The motor has been rebuilt with a higher than stock lift on the cam and the motor has been bored .030 over and besides that everything is stock, except exhaust, k&n's, airfoil. Since i've had it I had some high idle and inconsistant idle.(Idles around 1100 then jumps to 1400-1600 making the car jump at stops and sometimes jumps way down and cuts off) I took it to my mechanic and he went over it bottom to top with his decision being that the problem was in the chip and recommended I got a custom one for that cam specs. Other than the idle it runs great.
Would the wrong or stock chip make the car idle high and inconsistant?
If I do get a chip should I go with a custom chip for the specs of the cam or just a aftermarket stage 2 chip from hypertech? If I get a custom chip, I do plan on adding bigger injectors, 52mm TB, and swapping intake/runners eventually. Would I have to get another custom chip made for those mods as well?
Thank you for any information,
Andrew
Reply 0
Mar 17, 2009 | 06:55 AM
Re: 91 5.7L Z28 Problems
Depending on the specs of the cam, the less forgiving speed density system / computer (chip) may not cooperate and cause run issues.
Contact the folks at http://www.pcmforless.com (they also build chips) and check into a custom chip that will match your cam profile.
Reply 0
Subscribe
