speedometer?
speedometer?
Alright i'm back at it again. the speedometer wasnt working so i figured that it was the speedometer cable because it looked pretty bad. Well i replaced the speedometer cable and guess what. it still dosent work. I have spun the speedometer and it seems to be working. any ideas?
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: speedometer?
Ide guess the speedometer gear where the speedo cable goes into is stripped out. Does the cable spin when the cars moving?
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: speedometer?
better way to figure it out, kinda more of a neighborhood cruise deal, keep the cable hooked up to your trans and drive it a few feet, maybe around the block without your cluster in, see if it still spins if it does id suggest the gear as pointed out above. you can get a new one OR you could just look for a new speedo let us know how it turns out
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: speedometer?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: speedometer?
Maybe something in the following link will be helpful:
https://www.thirdgen.org/forums/inte...eedo-woes.html
JamesC
JamesC
Re: speedometer?
If you have a T-5, the sticky may be helpful (posting your car's make, model, year, motor, trans, etc.) is always helpful when answering questions
JamesC
JamesC
Engine: 5.7L/350
Re: speedometer?
Automatic is 700R4, manual is T5. The first thing to do is get under it and take off the speedometer adapter off (the thing the cable screws into) and see what the gears look like. Properly supported of course. Be safe.
Re: speedometer?
so i took out the speedometer gear. All the gears look good. The only thing that is wired is that when i put it back on the speedometer now works!?! However i dont know what i did that fixed it. i dont think its right however. the tranny came out of a 80s model firebird would this have a diffrent rear end ? to cause the speed to be diffrent? thx
Re: speedometer?
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Elephantismo
Feb 13, 2019 12:51 AM
