Fast Idle When Cold
Old Mar 26, 2009 | 07:06 PM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Fast Idle When Cold
So now that I can start my beast without fear of killing the starter. It's idling at 1300rpm until it warms up, which takes about 7-8min. My check engine light isn't on and it seems to be running fine after warm up (maybe a little rich). The vacuum motor in the thermac air cleaner is working, but there's no pcv filter (do I need that?). Also, I did what the Haynes manual says about pushing up on the egr valve to see if it's stuck. It seemed very hard to move, could that be my problem? Sorry, I usually work on pre-emission cars.
Alex
Old Mar 26, 2009 | 07:48 PM
kcallais's Avatar
Car: 1985 Z28
Axle/Gears: garbage 2.73
Re: Fast Idle When Cold
1300 when cold sounds ok. the pcv filter will keep crap from getting sucked through if your air filter gets dirty, thats about it. the egr valve shouldnt be too hard to push, but if the car is running fine as you say, id leave it.
Old Mar 27, 2009 | 12:33 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
1300 sounds normal - my LT1 idles around 1200 for a couple mins when its cold. 8 mins sounds like a long time though. Does it come down to a normal idle after that? If it does, I wouldn't worry about it.
Whats this about pushing the EGR valve? I've never heard of that...?
GTAman
Sep 21, 2015 09:57 AM
f-bodyz28
Sep 2, 2015 05:03 PM
destroyerwes
Aug 26, 2015 08:17 PM
86IROC112
Aug 21, 2015 07:20 PM
