LO3 coolant leak
Old Mar 29, 2009 | 08:34 AM
Icarus 402001's Avatar
Car: 92RS
LO3 coolant leak
Search showed no specific answers. I've been hunting down a coolant leak. I've had a constant, light coolant odor for a while now. Repeated pressure testing showed nothing obvious. Nothing showing wet. Yesterday, i noticed wetness at both front bolts on the intake manifold. This is a 123,000 mile LO3. I've been doing normal oil changes every 3,000-5,000 miles and found no milkshake, the radiator shows no oil when drained.
My car runs like a top( albeit a weak one). It's my DD. Since I don't find any metal in the oil, and I'm getting fairly good mileage( 22-24 mixed), I'm trying to decide if I should just re-gasket the top end or if I need to consider a crate engine.
Old Mar 29, 2009 | 11:20 AM
50bmgshooter's Avatar
Re: LO3 coolant leak
check to see if the bolts have loosened. if not its time to change the intake gaskets
Old Mar 29, 2009 | 07:47 PM
Car: 92RS
That would be nice. I'm not really looking forward to a swap any time soon.
Old Mar 29, 2009 | 08:03 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
water neck can leak slightly some to with no trace
tahe it off and stright edge it make sure its true and flat
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
ULTM8Z
Oct 2, 2015 01:25 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
