FUEL INJECTION TO CARB CONVERSION
Car: 1988 TA GTA
Engine: L98 Replaced w/ 350/330HP W/TPI
Transmission: Stock 700r4
Axle/Gears: stock 3:27
What would it take to convert a 1988 fuel injected TPI to a carb setup? I'm tired of all the sensors and headaches! My main concern is for the speedo, and factory gauges to work properly. What do I need to keep? And what can I get rid of?
Transmission: 4L80E/4L80E
There's a tech article on the topic linked from the thirdgen.org homepage.
Sensors go to the computer. Gauges have sending units. Disabling the computer (which, for the record, is illegal) will not affect the gauges.
Car: 1988 TA GTA
Re: FUEL INJECTION TO CARB CONVERSION
My car has the factory digital dash. So the dash should work, with the computer disconnected.
I haven't personally dealt with the digital dash, but from what I understand from this Board, the ECM and digital dash don't have anything to do with each other.
9192camaro
16
Feb 3, 2019 12:21 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
body, caburator, camaro, carb, carburetor, conversion, converting, efi, fuel, injected, injection, injector, l98, swap, thirdgen
