160 or 180 Degree Thermostat
Old Apr 2, 2009 | 07:14 PM
85FBTranam's Avatar
Car: 1985 Pontiac Trans Am
Transmission: BW T5, Hurst Short Throw Shifter
Axle/Gears: 3.70 Posi
Does anyone have any opinions on which temperature thermostat runs better in a 305 LG4 with a Carb. There is no computer in the car. Thanks in advance.
Old Apr 2, 2009 | 07:24 PM
RITTER's Avatar
Car: 1983 Buick Regal
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Re: 160 or 180 Degree Thermostat
You are not going to really notice any difference in the performance of your car whether you use a 160 or 180 degree thermostat. The 160 degree thermostat can actually be bad for your engine because it is harder for your engine to stay at 160 degrees so therefore the thermostat will almost constantly stay open. When this happens you run the risk of cold/hot spots in your cooling system because the coolant will just be constantly flowing.
Old Apr 2, 2009 | 07:29 PM
85FBTranam's Avatar
thanks, I have been running a 180, but in the middle of an intake swap and just wanted another opinion. So if I am not experiencing any overheating problems, no sense in a high flow thermostat either then?
Old Apr 2, 2009 | 07:34 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
just keep with a normal 180 one, remember the job of the thermostat is not to cool the engine it has no control on that, but rather its job is to force the engine to get warm....
Old Apr 2, 2009 | 07:40 PM
85FBTranam's Avatar
Thanks igotta355z28...stock 180 it will be.
sheachopper
Jul 31, 2019 11:27 AM
RedLeader289
May 28, 2019 01:47 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
