fuel pump replacement questions
Old Apr 2, 2009 | 10:11 PM
joshuamillerfd's Avatar
Car: 89 Iroc conv. & 03 Avalanche Z71
Engine: 5.0 TPI
I think my fuel pump is out on my 89 iroc. Does any one know if anyplace rents or loans fuel pressure testers? The car had been running ok but when you got up in the RPMs it would cut out and usually die. now it stats but dies almost immediatly. What do you guys think?
Old Apr 2, 2009 | 11:33 PM
toomany's Avatar
Re: fuel pump replacement questions
AutoZone will rent tools. I think Advanced will too. It does sound like the fuel pump could be on its way out. Better to check the presure before spending the $$$ on a new one.
Old Apr 3, 2009 | 06:53 AM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Autozone and Advance do not rent Fuel Pressure Testers. I have worked at both. You can buy a fuel pressure tester for around $24.00 - $39.00
Old Apr 6, 2009 | 10:53 AM
Engine: 5.0 TPI
The autozone in Muncie did rent a fuel pressure test kit $150 deposit. But it was not listed that they did on autozone.com. I don't know if all autozones do but the one I go to did!!!
Old Apr 6, 2009 | 11:34 AM
Damon's Avatar
$150 deposit!?!?! Oh, my. That's like buying 5 of them outright.
I have an extra one in my toolbox. I'll loan it to you for free and I only require a $100 deposit.
Old Apr 6, 2009 | 11:52 AM
ibmtech's Avatar
Car: 1987 IROC-Z
You can go to Walmart, Napa, Autozone, Standard, Advance and buy one for around $40.00.. I know autozone that when autozone rents the tools they basically cost only $5 or $10 more than the tool actually costs. The ODBII scanner we rent only costs $125 to rent.
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
justin57
Aug 20, 2015 07:05 PM
Kaweh
Aug 9, 2015 02:54 PM
