What machine work would I have to have done if I buy this block?
Old Apr 4, 2009 | 08:02 PM
toestothesun's Avatar
It's a Dart Block. The company I'm buying it from says it would need a wash, final hone, and cam and freeze plugs installed. Is there anything else I would need to get done before I began to assemble?
http://www.dartheads.com/products/sh...ll-blocks.html
Thanks for your help.
Old Apr 4, 2009 | 09:21 PM
TANGO's Avatar
Re: What machine work would I have to have done if I buy this block?
May need to be Decked . 0 Dech on the Pistons is the way to go .
Old Apr 5, 2009 | 01:17 AM
toomany's Avatar
Once you have your pistons and get them measured for the final hone. Have it washed/tanked install bearings/plugs and you should be good to go. It wouldn't hurt to check the bearing clearances though. I'd also check the mains...they shouldn't need to be line honed...but never hurts to check.
Old Apr 5, 2009 | 08:37 AM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
The early SHP blocks had problems with the line bores being out, so you'll definitely want to check that. You'll also want to doulbe check that the decks are square with a BHJ fixture and final hone it to the piston manufacturers specs.
italiano67
Dec 11, 2016 09:21 AM
Poncho92
Group Purchases
Aug 25, 2015 02:17 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Poncho92
Aug 7, 2015 08:15 PM
MENINBLK
Aug 5, 2015 11:58 PM
