Install fuel pump through tunk?
Old Apr 5, 2009 | 07:26 PM
joshuamillerfd's Avatar
Car: 89 Iroc conv. & 03 Avalanche Z71
Engine: 5.0 TPI
I have to replace my fuel pump in my 89 iroc. It has a full tank of gass (of course) In my 4th gen they cut an access hole in my trunk. I'm planning on doing this one myself. does any one know if you can cut an access in a 3rd gen? if so where exactly? What is the best way to close the access back up?
Old Apr 5, 2009 | 08:35 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Install fuel pump through tunk?
Geez, only discussed a million times. Yes, you can, no you shouldn't. :-)
Old Apr 5, 2009 | 09:03 PM
Pocket's Avatar
Car: 91 Trans Am
Also bear in mind the fuel lines are not like the 4th gen. You will have to cut them and repair them for an access panel job
Old Apr 5, 2009 | 09:15 PM
Engine: 5.0 TPI
thanks a lot Pocket. would I have enough room to drop the rear, exhuaust, and tank off a set of jack stands in the drive?
Old Apr 5, 2009 | 09:55 PM
jaygod8's Avatar
Car: 1986 Camaro Sport Coupe
Engine: 2.8L V6
I just did this last month and since I used to work In Heat Treating Metal I'm NOT worried about the supposed loss of strength in this "crumple" zone. Just use a thicker piece of metal (I used 1/4" to offset the lost Tensile Strength) and make sure to use Grade 8 sheet metal screws for attaching the new panel. (You will definitely need to seal the new plate with some fuel/oil Resistant Silicone) I used this "Sticky" as a guide for where to cut the hole: https://www.thirdgen.org/forums/faq-...tal-above.html
Old Apr 5, 2009 | 10:53 PM
1986iroc350's Avatar
Car: 1986 Iroc z
Engine: 350 tpi
just curious? why wouldnt you suggest it? The owner before me did it on my 86. Of course i found this out after i dropped the tank. what a pain in the $$s. Wis i had known about this access hole before. it would have saved me about 3 days labor working by myself.
Old Apr 6, 2009 | 03:49 PM
Pocket's Avatar
Car: 91 Trans Am
Depends on how tall your stands are, but most should allow it
Dont completely remove the rear, unbolt the shock mounts and lower it away with the DS, brake lines, TA, and LCA's still attached
Should be a 3-5 hour job as its a handful of bolts and some maneuvering of the tank
Yes Ive done it before
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
Grant2k
Jul 10, 2018 04:01 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
