ac delete box
Old Apr 6, 2009 | 08:35 PM
Grizzlybear226's Avatar
Car: 1988 Trans am
Engine: 358
ac delete box
i'm finally gonna un-clutter my engine compartment with a a/c delete pulley and rip all that stuff out. my question is if i can just use the stock a/c box for the heat still and not have to get a ac delete box
Old Apr 7, 2009 | 02:43 AM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: ac delete box
yes u can but i would recomend getting a AC delete box. it will really give u alot more room around that side of the motor.... for like the last couple header bolts etc.
Old Apr 8, 2009 | 09:33 AM
Car: 1988 Trans am
Engine: 358
Re: ac delete box
thanks, id also like to known if the f-bodys had transmission coolant lines, i'm pretty sure they didn't but i don't want to be ripping the wrong stuff out.
Old Apr 8, 2009 | 09:55 AM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
Re: ac delete box
they do, they screw into the radiator. they're a lot smaller than the AC lines so you shouldn't be able to mess that up
Old Apr 8, 2009 | 03:39 PM
Car: 87 TA clone
Re: ac delete box
trans lines arent actually cooler lines... they recurculate the fluid in the tranny resovour in the the radiator... which is GMs definition of a trans cooler lol. it does help so it works and u could call those lines trans cooler lines but its not a dedicated cooler.
the trans lines are the only 2 lines together on the pass side of the engine they are 5/16" and attach to the radiator on the pass side, one on the top and one towards the bottom, u cant really mess it up
83 Crossfire TA
Sep 18, 2015 12:01 PM
buckshot63
Sep 10, 2015 09:15 AM
83 Crossfire TA
Sep 8, 2015 12:06 PM
Silver Spear
South East Region
Silver Spear
South East Region
Sep 8, 2015 11:59 AM
