thinking about getting iron vortec heads
Old Apr 9, 2009 | 01:30 PM
Floorman279's Avatar
if i were to get iron vortec heads could i keep my stock tpi on there?
Old Apr 9, 2009 | 02:24 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: thinking about getting iron vortec heads
Nope.
You will need a new intake manifold.
I believe there exists a stealth ram or something that'll fit vortec heads. I think they charge an arm and a leg though...
Old Apr 9, 2009 | 03:58 PM
yea i heard that for iron heads these not only met what aluminum heads got but sometimes exceeded them in performance and are pretty cheap. i looked at that weiand/holley stealth ram intake and it costs about 800 or so.
Old Apr 9, 2009 | 07:47 PM
Pocket's Avatar
Car: 91 Trans Am
Vortecs are popular because millions of trucks had them factory and could be salvaged from JYs for very cheap
Compared to other factory heads, they might as well be race-prepped
Compared to most aftermarkets they fall short
Vortec HSR should be significantly cheaper
http://store.summitracing.com/partde...5&autoview=sku
Use this and you can keep TPI
This is relatively new and looks pretty sweet. Cheaper than HSR, includes rails, uses LSx TB. Id take that over HSR
Old Apr 12, 2009 | 11:32 PM
rojas1826's Avatar
Car: 86 iroc-z
Engine: 305 tpi
Transmission: 700r-4
Axle/Gears: 2.73 lsd
so if i go with edelbrocks vortec manifold and runners will these give me as good performance as the stealth ram
Old Apr 13, 2009 | 05:02 PM
so the edelbrock 3817 will work with a stock tpi setup?
Old Apr 13, 2009 | 05:09 PM
ok never mind about that. in the end it actually seems cheaper just to buy the aluminum heads and keep everything else stock becuase with the hsr you need to do a little customizing with your hood
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
