have to shift into 5th before reverse
Old Apr 13, 2009 | 09:19 PM
87whiteiroc's Avatar
Car: 87 Camaro
Engine: 5.7 350 TPI
hey i have a camaro with a 5 speed. i bought the thing with a hurst shifter already installed in it. i dont remember if it has always been like this but when i want to shift into reverse i have to put it in 5th gear first. the reason i have to shift there first is if i dont the gears grind. anyone know why this happens let me know
Old Apr 13, 2009 | 09:24 PM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Re: have to shift into 5th before reverse
My car does the same thing, always has as far as I can remember.
Old Apr 13, 2009 | 09:58 PM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
a lot of t5's are this way. there are no synchros on reverse. you put it in a forward gear to stop everything from spinning so it can go into reverse without grinding.
Old Apr 14, 2009 | 01:12 AM
johnny89345's Avatar
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
thats normal dont worry about it
Old Apr 14, 2009 | 01:36 AM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
its normal, another way to prevent it from grinding is to start the car in reverse, because most of the time when you are putting the car in reverse is right after a start up anyway, but other than that, just put it in a forward gear first.
Old Apr 14, 2009 | 07:41 AM
noboostnogo's Avatar
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
most of the manual cars ive driven(domestic and imports) have done this. Ive gotten used to it so i just shift into 1st then 2nd and then reverse without releasen the clutch. it has always worked for me and never grinds
Old Apr 14, 2009 | 09:02 AM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
agreed.....normal.....putting it in foward gear stops trans., cause of no reverse syncros........
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
DARKmj16
Sep 9, 2015 04:07 PM
