plz plz helppp fuel pump questions
Old Apr 24, 2009 | 05:31 PM
Dwms23's Avatar
Car: 91 camaro z28
Engine: 350 borred out t a 383
im swapping an 87 sb chevy into a 83 camaro the fuelpump is on the engine but does the 83 camaro have an in tank pump and if it does how can i make tis work without spending alot of money plz help im doing the swap tommorow morning
Old Apr 25, 2009 | 05:35 AM
Damon's Avatar
Re: plz plz helppp fuel pump questions
The 83 just has the fuel pump on the block. What kind of engine is the 87? Block-mounted fuel pumps only work with carburetors, not FI.
Old Apr 25, 2009 | 07:10 AM
Dwms23's Avatar
Car: 91 camaro z28
the engine was fi but is now carbeurated there two lines coming from the gas tank i kno 1 connects to the fuel pump but what does the second one connect two theres nothing on my fuel pump it can connect to
Old Apr 25, 2009 | 08:38 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
If you use the Camaro fuel pump it will have the place for the second line . The second line that should be smaller is for your return line .
Old Apr 25, 2009 | 09:49 AM
Damon's Avatar
Yes, the larger 3/8" line is the feed line from the tank to the pump, the smaller 5/16" line is the return line back to the tank. Only factory mechanical pumps used a return line. If you go with an aftermarket/high volume fuel pump it won't have a fitting for the return line. In that case you can just plug the return line and leave it unused.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
