What to buy?
Old Apr 25, 2009 | 08:56 AM
jboyd91's Avatar
Car: 91 Camaro z28
Engine: 350 5.7
What to buy?
Hey guys I have recently purchased a 91 camaro and am in the process of a cam swap but was wondering what works the best for these cars to get that lopey idle sound. The car has a 350 5.7 V8 in it.
Old Apr 25, 2009 | 09:36 AM
Vader's Avatar
Re: What to buy?
Since you are under the umbrella of Daley, and will likely have to pass an emissions test, the thing which will provide an idle lope may also prevent you from passing the sniffer test. Your pre-1996 car has to pass the single speed/idle test in Ill-Noise. A cam lobe profile with excessive overlap will cause lope, but will also cause raw fuel to exhaust. That will cause you to fail to qualify for license plates.
You might consider a better cam choice and sacrifice the lope for a little more power.
Old Apr 25, 2009 | 10:51 AM
MI ROC-Z's Avatar
Car: 89 IROC-Z
Engine: L98 5.7 liter
Transmission: TH700r4
Axle/Gears: limited slip 3.23
Re: What to buy?
Thats interesting about having to pass the single speed/idle test I thought all 95 and prior cars were exempt as long as they passed emissions before they became exempt. I guess I'm going to have a hell of a time seeing as how I dont have a catalytic converter on my car! LOL
Old Apr 25, 2009 | 12:38 PM
jboyd91's Avatar
Car: 91 Camaro z28
Engine: 350 5.7
Re: What to buy?
Which cam or cams would you recommend that would increase power but still be able to pass emissions?
Old Apr 25, 2009 | 12:50 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: What to buy?
I agree with Vader. If you want something with a sticker stating the legality, I'd suggest Comp's 210/220-112, .480/.480" cam. With TPI, there's really no point in considering the 220/230-114 cam.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Reid Fleming
Oct 10, 2015 09:56 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
