Oil gauge needle at 0
Old Apr 29, 2009 | 04:48 PM
Marshallbux's Avatar
I have an 88 camaro iroc with a built 5.7lt 350. I noticed my oil gauge was at 0. The needle was not moving at all. My temp. gauge remained in the normal areas and my engine ran fine and made no foreign sounds. Should i be worried about damaging my engine? Some say it may just be a bad gauge. Any suggestions would help...thanx
Old Apr 29, 2009 | 07:51 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Oil gauge needle at 0
more likely than not the problem is a bad sensor . they are not known to last more than 20+ yrs. . to replace one they are above oil filter , dirty & covered with crud . be careful with old , brittle plastic connectors going to it . to replace is pretty straight fwd. & cheap . good luck .
Old Apr 29, 2009 | 07:54 PM
Thanks for your advice. I figured it was something to do with a sensor considering i had no increase in engine temp or decrease in performance. Just worried me a bit when i first noticed it!! Scary sight to see needle at 0!!! haha
Old Apr 30, 2009 | 10:29 PM
BtownZ28's Avatar
Car: 1984 Z28
Engine: 305 LG4
Originally Posted by Marshallbux
I figured it was something to do with a sensor considering i had no increase in engine temp or decrease in performance. haha
And your engine still works!
Old May 1, 2009 | 12:55 PM
still works great. jus did a tune up after i noticed one of my plug wires had melted thru a lil bit and was shorting out so i was running 7 cylinders.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
TrevinE
Sep 14, 2015 03:20 PM
86IROC112
Sep 11, 2015 04:04 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
