Put air back on a delete car?
Old Apr 29, 2009 | 09:21 PM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
I just bought an 88 T/A with a 350 TPI. The previous owner deleted the A/C so there is nothing but a delete pulley there.
How hard would it be to put a complete A/C system from an '86 TBI back on this car? What should I look for?
Thanks!
Old Apr 30, 2009 | 01:20 PM
Sparkytfl's Avatar
Car: 85 TA (sold), 88 Corvette, 02 Monte
Re: Put air back on a delete car?
Was just the compressor and some hoses removed, or was it a thorough removal of all the wiring, the box on the firewall and the controls replaced with non ac ones, etc?
Old Apr 30, 2009 | 03:53 PM
gcgarner's Avatar
The box on the firewall is gone. The controls are still there. But I can get a box off of an '86. Thanks for the reply!
Old Apr 30, 2009 | 04:16 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The firewall box would be okay, but the '86 compressor is v-belt mounted on the driver side, and '88 is serpentine mounted on the passenger side.
Old Apr 30, 2009 | 04:50 PM
gcgarner's Avatar
OK, well, it must be newer than an '86 (the scrap yard guy told me it was an '86, and I didn't bother to look at the VIN), because it has the same serpentine setup as my car.
What would be involved with reconnecting everything? I'm pretty sure the radiator lines on mine have been plugged.
Old Apr 30, 2009 | 04:51 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Should be easy to do, sounds like the bracket is there you just need to pull the deleat pully off and install the AC compressor. The Hoses can be baught new from NAPA. The AC evapirator housing should be the same as thg 1986 set up. condenser can prob. be pulled from the 86 also.
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
86IROC112
Aug 17, 2015 02:00 PM
drathaar907
Aug 6, 2015 04:20 PM
