Possible Rod Knock
Old May 3, 2009 | 01:14 PM
Blue_Thunder's Avatar
Car: 1986 Chevy Iroc-Z28
Engine: 1989 TPI 350
Axle/Gears: stock 10 bolt with 2.73 gears
Possible Rod Knock
I noticed after taking my 86 Camaro to a show yesterday that while I was coasting at low speeds or put my car in neutral a knocking sound would come from underneath the car. The oil pressure is fine. I can only hear the noise when I am coasting at slow speeds with no load or when I put the car in neutral sitting still. The knocking increases in tempo as I increase the rpms. It doesn't do it all the time. The noise is there only after driving the car for about 30 minutes.
1986 Iroc with a 1974 350 from a police impalla. Has the TPI setup off of the 86 305. I have no idea whats been done to the internals on this engine. From the looks of it its the stock 74 block from the impalla.
RedLeader289
May 28, 2019 01:47 PM
Ed1LE
Sep 30, 2018 09:14 AM
bigjay89gta
Oct 15, 2015 08:04 AM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
