fuel pump
Car: '84 Camaro
Engine: LG4 305/5.0L HO
Transmission: 4 speed auto(700R4)
Axle/Gears: 3.08
fuel pump
ok my fuel pump to a dump in the middle of town the other day and now i have to replace it, only 3 days after it was registered and insured. i have an electric fuel pump but i dont if it puts out the same pressure.
how much pressure does a stock mechanical fuel pump off of a 305 "H" LG4 put out?
any help would be greatly appreciated
Transmission: 4L80E/4L80E
About 5-6 psi.
The LG4 and L69 use the same mechanical pump.
Where exactly is this electric pump of which you speak? There should be one in the fuel tank as well as the mechanical on the engine block.
Car: '84 Camaro
Axle/Gears: 3.08
Re: fuel pump
there is only the mechanical on the block. the electrical pump is a pump i have from another project that puts out 5-7 psi. is this too much for my car? its not in the car
Car: 87 iroc z
Engine: 358 tpi
Transmission: 700r4 with transpack
Axle/Gears: 3.42 with powertrax
Re: fuel pump
id throw a regulator on that elec to be shure you keep it at 5 to 7 you can put a gage on the elec to see what it pushes too
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
