Blown emissions
Old May 15, 2009 | 09:29 AM
Realmac4's Avatar
Car: 1991 Z-28/ '94 Impala SS
Engine: 355 TPI/ 350 LT-1
Transmission: T-56 in both
Axle/Gears: 3.73 / 4.56
Blown emissions
91, Z-28, HSR, has passed this before in the past, tail pipe test, has a cat, and only drive the car 9k miles in TWO years, and has not been messed with in that time, blew a 2488 HC at idle here in Delaware. Any suggestions? Also has older SLP exhaust/muffler and they say it is too loud, 103 db. Anyone know of a good "quiet" muffler I can put on for insp. Thanks
Old May 16, 2009 | 11:36 PM
dr.fiero's Avatar
Car: '91 S10 Blazer
Engine: TBI 350
Axle/Gears: 3.73 posi
Re: Blown emissions
If it's sat around that much over that length of time... I'd start by guessing stuck/clogged open injectors.
Hook up a pressure gauge, and an injector tester. Cycle the pump, note the pressure. Fire the injector a given amount (3 times, whatever) and note the pressure.
It should drop the same amount on each one. If you can't maintain pressure at all, then just pull them all out, hook them back into the rail and pressurize it. You'll probably see it leaking.
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
racereese
Oct 3, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
383backinblack
Sep 25, 2015 11:31 AM
