Rs sputtering and backfiring
Old May 15, 2009 | 05:59 PM
Irocz207's Avatar
Car: 90 Camaro RS
Engine: 3.1
I have a rs 3.1 that i just replaced the fuel pump and filter in and now it idles rough and has no power when accelerating and dies some times. I know the car is running lean because i saw smoke coming from under the seat and i looked uner the car and the cat was glowing. I think it may be the o2 senser anyone know anything i can do?
Old May 15, 2009 | 06:07 PM
Irocz207's Avatar
Car: 90 Camaro RS
Engine: 3.1
Re: Rs sputtering and backfiring
bump
Old May 15, 2009 | 07:04 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
what wire or tubes are next to the filter that you could hae bumped and what is near the jack?
how about the air injection to the cat? has it been disconnected or pulled away? or any of the lines to it.
i dont know what is near that part of the car and im only guessing.
sounds like the cat is not getting air. it is supposed to be hot but not glowing.
check the leads - strange that as soon as you go under the hood you have a problem.
have you looked at the error codes? go here and all you need is a paperclip and you can get the wrror codes. http://www.freeautomechanic.com/diag...blecodes5.html
db057
Apr 28, 2019 07:45 AM
racereese
Oct 3, 2015 03:46 PM
85 Jimmy
Sep 30, 2015 07:56 AM
RedLeader289
Sep 23, 2015 06:50 AM
Racerx974
Sep 19, 2015 10:16 AM
