Most Bang for My Buck?
Old May 26, 2009 | 07:16 PM
steviewonder's Avatar
Car: 87 Trans Am
Hi, I'm new here, I just bought an 87 Trans Am 5.0 4BBL Carb mostly stock as far as the engine goes and I was wondering what would be my best bang for my buck as far as getting more HP out of this thing? I'm not looking to spend a whole lot but would be willing to shell out like $1K or so, any ideas from you guys would be GREATLY appreciated! Thanks!
Old May 26, 2009 | 09:11 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Re: Most Bang for My Buck?
N2O will make the most HP for the money. Or if you don't like that idea start off with exhaust, then intake and heads. A numerically higher rear end will help with the "feel" of the hp. This is just my opinion.
Old May 26, 2009 | 09:40 PM
Car: 87 Trans Am
I talked to my mechanic and he said that for $1100, I could get a better intake, headers, and a cam......he said that with all of that I should see a jump of about 50-60 HP this sound right to you?, I'm not to big on the N2O option although I know it would be my best option, aby other ideas?
Old May 27, 2009 | 02:11 AM
Camarslow's Avatar
Car: 1984 Z28
Engine: none
Transmission: none
That's a great start, but all those mods with an inexpensive set of vortec heads should be some thing you may want to look into. You can probably gain 50hp on your factory heads but they will always be holding you back, if your going to go as far as a cam swap you might as well do a head swap while you're at it.
Old May 28, 2009 | 01:17 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
better to do exhaust before headers, and better to do rear gears before a cam
Old May 28, 2009 | 04:49 PM
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
$1100 could also get you a complete exhaust system, headers to tailpipe, depending what you find. Intake swap won't make a noticeable difference until you've done pretty much everything else to the engine. I doubt you'd get 50 hp with a cam swap if you haven't done the exhaust unless you went quite aggressive. IIRC the 87 LG4 should have the 416 heads which can be worked to flow up to 300 or so HP. If you've got a manual trans it should have 3.23 rear gears, which are alright to move down the priority list compared to 3.08 or 2.73. There's a great thread about making these engines go here, pay close attention to sofakingdom's post.
69GTOby
Apr 18, 2016 02:34 PM
BrianI
Oct 3, 2015 12:57 PM
Giocio
Oct 1, 2015 12:20 PM
Damon
Sep 26, 2015 04:29 PM
Mr. Chevy
Sep 11, 2015 06:06 PM
