coolant not circulating
Old Jun 1, 2009 | 07:43 PM
bwtaylor84's Avatar
Car: Camaro
Engine: 350 .40 over
Transmission: TH400 TCI
I just put in a summitt universal radiator, new water pump, and themostat 3 to be exact. the coolant will not circulate top hose stays hot and the bottom one is cold. I have no heater core. I have plugs in the intake and I took one out to see if it was flowing and it flowing real well. The temp gets real high like 260, 270 . and also I have flushed the radiator several times.
Old Jun 1, 2009 | 10:04 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: coolant not circulating
Double check and make sure you have the correct water pump. V-belt and serpentine pumps turn in opposite directions.
sheachopper
Jul 31, 2019 11:27 AM
Twinn Engines
Sep 25, 2015 06:27 AM
