Fuel Pump
Old Jun 6, 2009 | 01:25 AM
MitchellDeMoor's Avatar
Car: 1991
Transmission: 700
Fuel Pump
Hello, I have a 1991 Camaro 305. It is all stock now but I am doing a rebuild. I bought a 1976 L82 that I will be swapping in. I am 99.99% sure I will need a new fuel pump. Anybody done this before and have a good part number for one. Or one they can suggest? Thanks guys.
Old Jun 6, 2009 | 11:19 AM
Vader's Avatar
Re: Fuel Pump
Your '91 has an electric fuel pump. The L82 used a mechanical pump. If you are planning to use the carburetor from the L82, you can use the electric pump with a regulator.
As a side note, you're going to have to do a lot of work to the L82 to get it to equal the '91 305. The heads are genuine cast crap. You might even consider using your 305 heads on that engine just to get decent compression. L82 was usually stuck with 76CC heads, a low profile intake, and a poorly matched cam.
Old Jun 7, 2009 | 02:55 AM
Car: 1991
Transmission: 700
Re: Fuel Pump
The heads worked in the Corvette so why would it not work in the Camaro? If I swapped the heads from the 305 would I also need to swap the cam? Thanks man.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
