How much power can I expect to lose on the dyno??
Car: 1988 Camaro(92 Z28 clone)
Engine: Forged 383, AFR 195 419/430@wheels
Transmission: Monster 700R4 Yank 3600 stall
Axle/Gears: 9in Detroit locker-3.90's,35 spline
My 88 camaro with a 383 stroker made a healthy 419HP and 430Ft. Lbs. to the rear wheels running through a WC T5. In a few weks here I will be switching over to a heavily built 700r4, and am fully aware that automatics have a higher percentage of power loss. What kind of numbers could I be expecting to see if I were to dyno the car again, but with an automatic?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: How much power can I expect to lose on the dyno??
Depends on the converter stall speed, depends how the tranny is built. If you want a guess, pick a number from the hat. If you want to know an exact number, put it back on the dyno.
sailtexas186548
Aug 24, 2015 10:11 PM
