oxygen sensor pic help
Old Jun 12, 2009 | 07:35 PM
WSX123's Avatar
Car: 1988 Trans Am GTA
is this green wire for the o2 sensor?
Old Jun 12, 2009 | 07:47 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Re: oxygen sensor pic help
That would be a temperature sensor. FYI, that's not a good way to hook up two sensors because the water won't really circulate accross the sensors. This is assuming that the other thing connected at the bottom is another sensor.
Old Jun 12, 2009 | 07:50 PM
WSX123's Avatar
i am looking for the o2 sensor wire, if anyone could help me locate it. i wanted to put in a air/fuel gauge
Old Jun 12, 2009 | 07:57 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
The O2 sensor will be screwed into the exhaust system somewhere close to the engine. Mine is on the driver's side.
Old Jun 12, 2009 | 08:05 PM
WSX123's Avatar
thanks
Old Jun 12, 2009 | 08:20 PM
KatsCam's Avatar
Car: 1991 Camaro RS Coupe
Engine: 5.0-liter (305) TBI V8
Transmission: 700R4-speed automatic overdrive
Axle/Gears: stock/2.73
Driver's side, near the exhaust manifold. It looks like a spark plug on one end. Follow the wire, which should have a plastic housing on the end.
GTAman
Jul 3, 2024 07:29 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
snakeshooter
Sep 7, 2015 11:15 AM
willyjoejr
Sep 3, 2015 09:26 AM
