anybody use these?
Old Jun 15, 2009 | 08:09 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
anybody use these?
http://www.dartheads.com/products/cy...s-s-heads.html. also will these bolt on to a 350 with no problem? i got theses heads complete and almost brand new for $125 bucks! im running a carb setup and an edelbrock intake if that helps
Old Jun 15, 2009 | 08:20 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: anybody use these?
Check the numbers on your heads vs the ones on the web site. It looks like they'll fit no problem and since it says they fit 1955 through 99 and including vortec style, that means they are tapped for both centerbolt and permieter valve covers. However, if yours are the vortec style, you will need a vortec intake to accomodate them which may or may not screw up your A.I.R. system and EGR.
Old Jun 15, 2009 | 08:26 PM
Engine: 355
i have the normal intake setup and they only accept the centerbolt style valve covers. i dont have egr or air system so no worries there i was curious if my intake would fit. i got them off a guy who had a 350 with the stock tpi unit.
Old Jun 15, 2009 | 08:39 PM
Ozz1967's Avatar
Car: 1984 Trans Am
ICheck the part number on them against the ones on the web-site. You may need to email them for better confirmation. The Vortec style heads have different port heights that are incompatable with the standard style intake like yours so you'd need to switch intakes if indeed they are vortecs.
