Replacing serpentine belt
Old Jun 17, 2009 | 12:01 PM
KatsCam's Avatar
Car: 1991 Camaro RS Coupe
Engine: 5.0-liter (305) TBI V8
Transmission: 700R4-speed automatic overdrive
Axle/Gears: stock/2.73
So, I need to replace the serpentine belt on my car. Looks fairly simple - let the alternator loose and swap it out. But I am wondering if anyone has any tips for me. How do I know how tight it should be when I get it back on? Anything specific I should or shouldn't do? Thanks!
I am fairly mechanically inclined. Am also replacing thermostat, which I have done before. Have rebuilt a careburetor, done brakes. Just want to make sure I don't monkey this up, since it runs the entire show.
Old Jun 17, 2009 | 12:15 PM
watson90z's Avatar
Car: 1990 iroc-z
Engine: 350 tpi
Axle/Gears: 3.23 posi
Re: Replacing serpentine belt
you dont need to losen the alternator just release the tensioner (sp)? lol then pull the belt off and when you get it all back on right just open the tensioner again and slip the belt underneith.
Old Jun 17, 2009 | 12:16 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Sorry, but that isn't going to work with a serpentine. It's way easier than that. You get yourself a half inch drive ratchet and use it to pull the tensioner back. The tensioner has a 1/2" square hole in it just for this purpose. You don't remove or loosen any of your accessories, just take the tension off so you can change the belt.
Old Jun 17, 2009 | 02:15 PM
KatsCam's Avatar
Thanks!
Old May 28, 2010 | 08:33 AM
gregmy123's Avatar
Hi,
Is there a special tool for belt replacement for:
91 Camaro RS/305L?
Thank you!
Old May 28, 2010 | 12:59 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Special tool? A ratchet should fit into the auto tensioner and allow you to pull it back to release the pressure on the belt. The belt then just slides off, align your new belt on your pulleys and make sure you've got it going the right route, pull back the tensioner again, put the belt under the tensioner pulley, and slowly let the tensioner down. Should only take five minutes. The hardest parts are not pinching your fingers between the belt and pulleys and making sure you get the belts to line up on the pulleys. If you get belt over off the end of the pulley it'll try to toss and shred the belt later when you start it up.
Old Oct 15, 2015 | 02:41 PM
RedRagROC89's Avatar
I just did mine on an '89 TPI IROC conv. The old tensioner had a 1/2" hole for a breaker bar to release belt tension, but the new one did not. There is a Torx 55 holding the tensioner on. That's all! If your new one has no 1/2" hole, the trick here is to get a socket on the bolt that actually holds the pulley to the spring mechanism, It's a metric, which I didn't have, but I got an SAE close enough. The bolt is left-hand thread so it won't come loose if you start cranking on it. I really do suggest borrowing or better, buying a breaker bar. You just never know when one will come in handy!
Bob
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
mustangdmurder
Aug 21, 2015 07:17 PM
jahblah
Aug 12, 2015 05:54 PM
