compression
Old Jun 19, 2009 | 09:09 PM
jkmj999's Avatar
Car: 91 Chevy Camaro z28
Transmission: auto
compression
got a 91 Chevy Z28 ,engine idles rough @ 2 or 3 seconds interval ,when turn on the AC it idles ok , or after i drive it for 30 minutes or so it idles ok too, my friend told me it could be the compression, there is oil leak @ the top back end of the engine. if it's a compression issue does car should have rough idle all the time
Old Jun 19, 2009 | 10:54 PM
lunaticinaZ's Avatar
Car: 1991 Black Z28 G92
Engine: 350 for now
Transmission: wc t5
Axle/Gears: factory 3:42
Re: compression
check the fuel filter. sounds to me like it might be on its was to being clogged. at idle its not pulling enough fuel to idle smooth but when the ac is turned on it raises the idle or when u drive it there is better flow. I'm not master tech but it couldn't hurt to check. and hey if I'm right... thats a cheep fix
and dropped compression on a cylinder would cause a "miss"
constantly no matter what rpm
Old Jun 21, 2009 | 12:17 PM
jkmj999's Avatar
Transmission: auto
Re: compression
thank you Mick
FormulasOnly
Jul 23, 2018 08:47 AM
69GTOby
Apr 18, 2016 02:34 PM
Nervous2
Oct 8, 2015 10:53 PM
Jonas Earl
Sep 27, 2015 07:39 AM
WhteRbt
Sep 21, 2015 09:48 AM
