MSD wiring?
Old Jun 23, 2009 | 12:44 AM
Black Z28's Avatar
Car: '88 Iroc-Z z28 Camaro
Engine: Carb 355
Transmission: t5 5-speed
Axle/Gears: 4.11
MSD wiring?
I know how to run them and everything like that cause theres the diagram on the back of the box itself but however what color wires go to what wires? you got a black and an orange from the box going to the coil when the coil has a red and white wire? then you have the red wire that goes to the timing control or something like that? im way confused as to where that goes. I need msd owner help! Thank you
Old Jun 23, 2009 | 07:43 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Re: MSD wiring?
http://www.msdignition.com/pdf/WireDiagrams/WDTN.PDF
take a look at this and see if your diagram is in there.
Old Jun 23, 2009 | 06:12 PM
Black Z28's Avatar
Engine: Carb 355
Axle/Gears: 4.11
Re: MSD wiring?
Ok now i got everything, but where does the white wire for the trigger hook up to?
Old Jun 23, 2009 | 06:24 PM
Black Z28's Avatar
Engine: Carb 355
Axle/Gears: 4.11
Re: MSD wiring?
Op nvm i think i got it, the wires from the coil go to the black and orange and then the other wires from the dist. go to the red and white. ok nvm, thank you
stalkier
Dec 6, 2015 11:25 PM
LittleFranks
Sep 17, 2015 12:22 PM
overdriv
Aug 20, 2015 03:52 PM
midias
Aug 15, 2015 05:07 PM
tartagliaz28
Aug 15, 2015 10:59 AM
