Wont crank, ran fine before yesterday
Old Jun 23, 2009 | 10:06 AM
gangsta_money23's Avatar
Car: 1982 Camaro Z-28
Transmission: manual
So I go out to start my 82 z-28 camaro only to find out the battery was dead which was no suprise I knew I needed to replace it, so I hook it up to one of my other cars to jump start it and on the inside voltmeter it shows the batterys charged so I try to start it and theres no cranking at all. Ok it tried to crank once then nothing at all. It did sit for about a week while i was out of town but before that it started every time. Where should I start on the list of possible causes? Thanks alot
Old Jun 23, 2009 | 11:05 AM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Re: Wont crank, ran fine before yesterday
Replace the battery first, your probably not getting enough juice to store in the battery and the jump is not enough to run the starter.
Old Jun 23, 2009 | 11:40 AM
frbdgirl92's Avatar
I had this problem this weekend. It was the battery - you don't have enough cold cranking amps to actually get the car started. The only way to fix this is to get a new battery.
Old Jun 23, 2009 | 12:45 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Considering it only sat for a week, with a jump start, you should at least see something happening at the starter, be it sluggish cranking, clicking, or the solenoid engaging. Are the cables all tight at the battery?
If the battery's bad then get it replaced, make sure the cables are nice and tight, and get your starter tested if it still is acting up.
BlueIroc-Z
Jun 9, 2019 03:22 AM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
NufNuffZ28
Aug 14, 2015 09:12 AM
mizz0313
Aug 12, 2015 06:45 AM
