Need help with shifter wiring..5 speed to auto
Old Jul 8, 2009 | 08:34 AM
paulmoore's Avatar
Car: 1988 Camaro(92 Z28 clone)
Engine: Forged 383, AFR 195 419/430@wheels
Transmission: Monster 700R4 Yank 3600 stall
Axle/Gears: 9in Detroit locker-3.90's,35 spline
Hey there. I am converting my 5 speed to an auto 700R4 and am trying to find out the wiring for the shifter. I got a shifter out of a 91 camaro. The shifter has a total of 6 wires. The wires are...
1 thick purple wire maybe 12ga
1 thick teal wire maybe 12 ga
1 small orange w/black tracer
1 small black w/ white tracer
1 small light green
1 small dark blue
The wiring diagrams I have show the neutral safety switch being the orange w/black and black w/white. I am pretty sure that the light green is for the reverse lights, but what are the other wires for?
Also, my clutch start switch has a yellow wire going into it and a purple coming out and goes to the starter. So do I take the yellow of the clutch start switch and have it go to the orange/black on the shifter? Then the black/white tracer wire from the shifter should go back to the purple of the clutch switch and the engine should start hopefully. Any help.info on this would be greatly appreciated. Thanks in advace!!!
Old Jul 8, 2009 | 03:39 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Need help with shifter wiring..5 speed to auto
I just today did this. My shifter is from a '91 Camaro I had, I just put it in my '86 S-10 that was built with a T5. But my shifter has a large yellow wire adjacent to the large purple wire, and these were easily spliced to the identical-gauge yellow and purple wires going into the clutch pedal switch. That got the 350 cranking in park. Right now I'm eating lunch, before tackling the other 4 wires from the shifter. I'll update tomorrow at lunch.
Old Jul 27, 2010 | 09:43 PM
OddJack's Avatar
^^^^ Hey Atilla, you done eatin yet?
Mine is a 89 Camaro Convertible.
The Bigger wires are Purple and Green with white stripe ( Clutch Safety Switch)
The two in the middle are blue and green, and they are for the Reverse lights
I dont know what the last two are for. Not needed for the swap I assume.
Backup, Back up, T5 conversion, shifter, cables, orange,
Old Jul 27, 2010 | 10:18 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Larger dk green wire is 12v+ coming into neutral safety switch from a starter enable relay (that you won't have since you don't have vats). You can run the larger yellow wire from your old clutch switch and splice it to the dk green wire.
Larger purple wire is 12v out to the starter - you can splice this into the large purple wire from your old clutch switch.
The rest I don't know off top of my head - one is for rear hatch switch (so it doesn't open when car in gear), one is for reverse lights, etc. Black with white tracer should be a ground I think. All the wiring diags here:
http://www.austinthirdgen.org/index.php?pid=19
There's alot of extra diags farther down the page for a 1992 - you can reference those as well as it would all the the same as the 1991 NSS wires.
Old Jul 28, 2010 | 12:45 AM
OddJack's Avatar
I had vats, looped it out a while back.
Old Jul 28, 2010 | 02:40 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Is the Park / Neutral INPUT switch ; not P/N safety switch
Lets ECM know car is in gear so it can adjust idle revs
Old Jul 28, 2010 | 11:56 AM
OddJack's Avatar
So when you do the swap, what do you do with those wires?
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
deracer
Apr 11, 2016 12:04 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
jbd1969
Aug 17, 2015 07:06 PM
