spark plug wires,,which ones for V-8 headers
Old Jul 8, 2009 | 01:57 PM
mooch1's Avatar
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
hi , i need new plug wires, i have headers so i need the insulated type, when i got the car it came with mallory 8.8mm wires, i want to change them now and i would need wires for a HEI distribuor and the plug boots all at 90' angle .any suggestions or better yet a part number?...thanks in advance,
Old Jul 8, 2009 | 02:01 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Re: spark plug wires,,which ones for V-8 headers
Check out the MSD line. They make good insulated plug wires with the 90 degree boots. Either JEGS or Summit Racing has them in stock. Go on their website and compare to what best suits your needs.
Old Jul 8, 2009 | 02:29 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
I've used stock, MSD, and Moroso wires with my headers and they all have ran well. However, I had a thick MSD 8.5mm Super Conductor wire that fell down a bit so it was barely touching the header and it melted pretty fast!
My advice is, regardless of what brand or thickness you buy, get some plug wire clips to keep the wires secure and as far from the headers as possible.
Hope this helps!
Old Jul 8, 2009 | 06:17 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
You can also buy insulator sleeves that go on the wire at the plug boot - they look like they're made of abestos, and about 6 inches long.
Old Jul 9, 2009 | 10:45 AM
MY87LT's Avatar
Car: 1987 Camaro LT
And you if you really want to dress up your engine compartment, maybe think about getting a good set of wire looms to have it all look nice and tight.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Bryan F
Aug 18, 2015 02:28 PM
