Plastic tube on passenger side
Old Jul 9, 2009 | 11:10 PM
philsblwnz28's Avatar
There is this black plastic tube coming out of the fire wall on the pass. side if the car. My A/C blows out the defrost vents and that tube is not hooked to anything, just hanging there. Can anyone tell me what it might be? Thanks
Old Jul 9, 2009 | 11:27 PM
Billy_Bob's Avatar
Car: 92 GMC Sierra 2500
Engine: 5.7l
Transmission: 4L70
Axle/Gears: GT4 3.73
Re: Plastic tube on passenger side
That is a drain for the A/C system. Just like a cold glass of water gets moisture on the outside of the glass and this can run down the glass onto your table, same thing with a cold A/C unit. It accumulates water. And this water needs somewhere to drain.
That inside section of coils which gets cold is called the "evaporator".
Old Jul 10, 2009 | 12:28 AM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
I believe you are talking about the vacuum line for vent control. The defroster vent is the default position if there is a vacuum loss. There should be a vacuum reservoir that is connected to manifold vacuum (a small canister or ball depending on what year your car is), then the vent control line is connected to the reservoir.
Old Jul 10, 2009 | 03:36 PM
Would you happen to have a picture I can see, I really want a/c in florida.....I have an 86 T/A with a carb (no computer) 305...There is a round canister under the front bumper, and a square one by the driver side headlight. Do I need a check valve also? Thanks for yalls help....
Old Jul 11, 2009 | 02:25 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Vac line should run from intake through check valve and split /or split at check valve as shown in pic .One line goes inside to operate your A/c controls and the other goes to the vac ball.This keeps your vac supply for when the vac drops like when you accelerate.
Pic from a TPI car but yours should have similar.
1992 Trans Am
May 10, 2023 07:19 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
corlando52
Interior Parts Wanted
Aug 24, 2015 11:32 AM
Cameeeero
Aug 20, 2015 03:06 AM
Street Lethal
Aug 14, 2015 08:25 PM
