92 rs fuel pump relay??
Old Jul 16, 2009 | 02:15 PM
slayernut's Avatar
Car: 92 rs camaro
Engine: 350 tbi
Transmission: 350 turbo with kit
Anyone know where the fuel pump relay is, i'm sure its on the site here somewhere but i cant find it. thanks in advance
Old Jul 16, 2009 | 02:19 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: 92 rs fuel pump relay??
Behind the Drivers side kick panel.
Old Jul 16, 2009 | 02:22 PM
slayernut's Avatar
Car: 92 rs camaro
Engine: 350 tbi
Sorry kinda new to this could you be more specific. Thanks again
Old Jul 16, 2009 | 02:45 PM
Wadebryant's Avatar
Jump in the drivers seat. The fuel pump relay is located behind the plastic kick sheild panel by your left foot. The relay is black and has four male connectors in it. Two screws to remove it, then seperate the relay from the harness. May or may not have numbers like, 14093107 or similar on it but there will be no mistake about it being a relay. You can pop the top of it off and check the coil and points in it. If it's not working, the contact points may be shot.
Good luck
Old Jul 16, 2009 | 02:51 PM
slayernut's Avatar
Car: 92 rs camaro
Engine: 350 tbi
Much appreciated!! thanks again
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Bryan F
Aug 18, 2015 02:28 PM
Kaweh
Aug 9, 2015 02:54 PM
