How to give my car that sound?
Old Jul 27, 2009 | 06:33 PM
805camaro805's Avatar
Car: 91 Rs Camaro
Engine: 305 tbi
Transmission: 700 r4
I have a 91 rs which i am working on. I want to give it that muscle car sound like this http://www.transamws6.com/video/ZepherWS6.mpg Is there anyway to give my 305 5.0 tbi that sound? If so what do i need
Old Jul 27, 2009 | 06:36 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: How to give my car that sound?
that my friend is a nasty cam, i say with atleast 270 duration on it, you would need the cam and a computer reprogram and a good exhust
Old Jul 27, 2009 | 06:37 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
You'd need a minimum of a bigger cam, headers, and catback exhaust to get that.
Old Jul 27, 2009 | 06:41 PM
Car: 91 Rs Camaro
Engine: 305 tbi
cam shaft? What type do i need? Jegs? http://www.jegs.com/i/Crane/270/WG1014K/10002/-1 ???
Old Jul 27, 2009 | 06:47 PM
89RS_82Z's Avatar
jegs or summit
cam selection is alot of what you want in the car how good you are (or your prom builder is)
if you are just wanting the thump there is a cam model called Thumper
i would say a 278 or so duration may do it, he may also have solid lifters its hard to tell on the video sound quality, solid lifters give you that nice "tickin" (lack of better words) with the cam tump
also with a 278 cam you will need a 2400 stall converter if you got a automatic
possibilitys are end less, the bigger cam you get less vaccum you have at idle what can be hell on power brakes and vaccum operated items on the car
unless you really know what you are doing with a motor and what the numbers are on the cam mean you should probably stay away from a cam swap
jhawkeye
May 25, 2022 06:33 PM
Reborn756
Sep 4, 2015 03:42 AM
midias
Aug 22, 2015 01:42 AM
mustangman65_79
Aug 8, 2015 12:07 PM
gwade12
Aug 8, 2015 08:17 AM
