part number for smog pump delete pulley?
Old Jul 29, 2009 | 02:58 PM
EROC88's Avatar
Car: 88 IROC-Z
Engine: 355 T.P.I.
Transmission: t56
Axle/Gears: gm 10 bolt, 3.90 gears
i have searched and searched this site to find the part number for the idler pully you put in so you can take off the smog pump. i have an 88 IRoc with a 350, Air conditioning, and serpentine belt. can somebody please tell me the part number i am looking for?
i really want to get rid of the air pump, and please no speeches about why doing that is wrong.
thanks!
Old Jul 29, 2009 | 04:36 PM
Gearhead291's Avatar
Re: part number for smog pump delete pulley?
thanks!
yea i need that too
Old Jul 29, 2009 | 06:17 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
yes its wrong but just get a shorter belt.
Old Jul 29, 2009 | 06:28 PM
EROC88's Avatar
Car: 88 IROC-Z
Engine: 355 T.P.I.
Transmission: t56
won't the shorter belt have vibration issues? several people have said their belts vibrate since there isn't any support between the ac and the crank. is that not true then?
and i know its wrong thats part of why im doing it
**** the EPA!!!
Old Jul 29, 2009 | 06:45 PM
TADailyDriver's Avatar
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
Your wrong. in fact you need to go with a longer belt. there is a tech article on here about it. you can leave the pump on your car and if you run a longer belt yu can bypass the pump completely. i just did this on my TA this weekend. you need a 96.8" belt and run it from the alternator down to power steering then instead of going to the crank from the PS go over the water pump then down around the crank and back to the ac pulley. I wil take pics of my setup if you all would like. but there is a tech article on here about it just go find it.
1992 Trans Am
May 10, 2023 07:19 PM
italiano67
Dec 11, 2016 09:21 AM
twest2k2
Aug 24, 2015 11:26 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
armybyrd
Aug 10, 2015 09:23 PM
