need more help w/iroc
Old Aug 24, 2009 | 08:42 PM
F16DCC431's Avatar
Car: 86 IROC
Engine: 350 High Torque
ok so i was having prob w/ carb flooding moter but i got that fixed by new seals now when car starts im getting a loud pop coming out of the carb in sinc w/ the engine the more rpm's more pops and when it pops fuel is misting out of the carb so i checked my timing and it is set to 10 degrees and when i add more rpm the time advaces to 20+ degrees so i don't have a clue could it be a plug distributer or something internal moter only have 3500 miles on it i drove to wichita falls texas from sc and now on my way to nd in 2 weeks so kinda need to get it fixed need some help guys you always seem to come threw thanks
Old Aug 25, 2009 | 08:47 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: need more help w/iroc
Well if you just did valve seals that means you just adjusted your valves as well? Unless im miss reading it and your saying that was done the car ran fine and then this developed? If im correct in my understanding my guess is an intake valve is too tight not allowing the valve to seat so every time that cylinder fires it blows past the valve and pops in the intake. Almost sounding like pop corn is cooking in your intake. Another possibility is an exhaust valve is too loose not opening and letting the hot burning exhaust gases exit so when the intake valve opens the fuel is instantly ignited backfiring in the intake. Either way i would inspect the valve train for proper operation and check the adjustment of the valves.
Old Aug 25, 2009 | 08:48 PM
Also although your timing sounds ok check the plug wires to make sure the right wire is going to the right cylinder.
Old Aug 25, 2009 | 10:14 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
sounds like backfiring - check all plug wires for continuity, check all plug boots make sure they are on plugs good, double check firing order, set timing with the vacuum line to the distributor plugged, or the EST disconnected if CC carb.
Old Aug 25, 2009 | 10:20 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Reajust your valves. sounds like you missed one. As a rule all ajusting nuts should look to be at the same spot on the studs.
89ROC-Z
Apr 16, 2009 03:48 PM
jinlos
Jun 3, 2006 12:39 PM
StockBastard
Nov 9, 2001 10:20 PM
BlazinOR
Nov 8, 2001 10:26 PM
