Timing pointer question?
Old Aug 28, 2009 | 04:57 PM
camaro87-alex's Avatar
Car: 1987 Chevrolet Camaro SC
Hi there..I have a simple question when it comes to the timing pointer.
I have a 87 Camaro that was original a 305 quadrajet engine in it.
Last winter i swapped the injection system to TPI. Changed wiring harness and everything is brand new...
My question is. After I got the TPI throttle body and air duct it is almost impossible for me to see the timing pointer. The pointer is right below the water pump and points about 12.00clock upwards if you know what I mean.
Shouldn't the timing pointer be placed about 2.00clock or something on the TPI engines?...
I just think it is so difficult to adjust my timing with the timing pointer so hidden. Another thing. There is a metal peace wich is sylinder formed, at the end of the pointer. Think it is called a magnetic probe hole or something?.What is that for?...Can I change my timing pointer?...Hope somebody could help me out here..
Old Aug 28, 2009 | 05:03 PM
dwinhofer's Avatar
Car: 1985 Iroc Camaro, 1974 type LT Z28
Engine: modified L98 corvette, L82
Transmission: 700r4, Turbo 400
Axle/Gears: 3.42, 3.42 posi
Re: Timing pointer question?
On my 1985 Iroc tpi the timing pointer is at about 1 o'clock. I just ran out and looked. It is pretty easy to see when I time it.
Old Aug 28, 2009 | 07:47 PM
Damon's Avatar
I'm pretty sure they went back to the older style 1:30 position timing pointer location on TPI engines for that exact reason.
You would need to replace the balancer for one designed to work with a 1:30 position timing tab (use one for an 87 TPI engine) and buy a bolt-on timing tab that goes in the matching 1:30 position.
Your will still read correctly, but it's obviously in an inconvenient location with the TPI snorkel directly in the way of seeing it.
Old Aug 28, 2009 | 11:25 PM
Ok..I sholud look for that then. Is it any special dimension on the balancer. I mean, I haven't measured the size..Is it 6", 7" or what??
I will try to do this like you mentioned..
Old Aug 29, 2009 | 06:09 AM
Damon's Avatar
The TPI balancer I mentioned is a 6-3/4" unit. Timing tab must be designed for that size balancer.
Old Jun 23, 2010 | 05:14 AM
jeinteriordesig's Avatar
Car: 86' I-ROC clone
Engine: 305 tuned port injection
I know this ia an older post but i have a similar issue i also have a 305 that i converted the intake to tpi i recently put a gear drive timing set that has a cover to go with it with the timing tab built into the cover at about 1:30 my factory tab is about 12:00
Old Jun 23, 2010 | 05:18 AM
I have rebuilt my engine last winter so I figured out how to do this.
I just bought a new harmonic balancer (damper) that had the TDC at 14:00.
Then I bought a timing cover with a seperate timing pointer that I assembled with 2 of the mounting bolts from the timing cover. Then the TDC was as "0" degrees.
I checked this with the heads of since I was doing an engine rebuild so I was completely sure that I did it right...
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
z28addict8490
Aug 7, 2015 08:48 PM
