what should i do?
Old Aug 31, 2009 | 03:38 PM
DARKmj16's Avatar
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
what should i do?
ok got me a 84 maro thats been sitting for a few years. its a 5spd 2.8L. now i now i need to change oil/coolant/brake fluid. brakes look rough so all the brakes are being redone. O2 senior and cat is beening replaced, air/fuel filters are beening replaced, new plugs/wires/cap/rotor buttion going on, and wiper blades, also PCV valve, thermastat going on and the carb beening rebuilt. all lights do work and battery is new. did i miss anything? or anything i need to check?
Old Aug 31, 2009 | 04:18 PM
pearlphoenix's Avatar
Car: 86 Trans Am
Engine: 383
Transmission: Probuilt 700r4
Axle/Gears: 2.77 BW 9 Bolt
Re: what should i do?
spark her up and go from there, sounds like you got a good start, have fun with your new third gen
Old Aug 31, 2009 | 04:32 PM
DARKmj16's Avatar
Engine: 305 tbi
ok thanks im sure i will. and ya i thought i had everything but wasnt that sure
Old Sep 10, 2009 | 12:28 AM
Richwiz1's Avatar
check all hosses and vacuam lines for cracks or dry rot and belts
Old Sep 10, 2009 | 03:09 AM
DARKmj16's Avatar
Engine: 305 tbi
yep got that, upper and lower raditor hoses replaced, belts replaced, wires bout to be replaced, and the vaccum hoses (all gazillion of em) look good.
