possible bad heater core
Old Sep 1, 2009 | 07:06 AM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
hey whats up....
i have just replaced my heater core less than a year ago.... now when i turn on the vents every now and then i can smell coolant through the vents.... also i was looking under the passenger side dash and was feeling up there and i had the moist of coolant on my hands... does this mean i have a bad heater core after one year.... i do know that i have a very tiny cut in one of the heater hoses where the engine bay is but the small leaked seemed to went away a few months ago.... could that be the problem... thanks
Old Sep 1, 2009 | 12:13 PM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Re: possible bad heater core
Replace the hoses. If you've got a crack in one there are probably more. Replace both of em and see if your problem gets better, if not it could be the core. I have to replace the heater core on my mom's 78 Camaro every other year. Then again we're using junkyard cores.
Alex
Old Sep 1, 2009 | 09:31 PM
88fastgta's Avatar
found my problem...took the heater core out and come to find out one of the tubes are cracked and was leaking from there.... got another heater core and will be installing it tomorrow... thanks guys...
Old Sep 7, 2009 | 09:36 AM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
Where did you get your heater core?
Old Sep 7, 2009 | 09:45 AM
88fastgta's Avatar
i got mine from autozone for 30.00.... has worked great every since i got the heater core...
Bubbajones_ya
Jul 6, 2024 08:32 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
Stryker412
Sep 20, 2015 06:59 PM
buckshot63
Sep 10, 2015 09:15 AM
