<1/2 Tank, Sputters, >1/2 or full Run Much better Whats Going On! Story Inside
Old Sep 4, 2009 | 08:06 PM
Slowridr's Avatar
Car: 1987 GTA Vert & 1991 GTA 5 Speed
Engine: 87 GTA-L98 91 GTA LB9
Transmission: GTA-700R4 & GTA T5
Have 87 GTA Vert w/ 88 Formula 5.7 TPI The person I got the engine from said it had 66K miles.
Heres what I have changed.
  • Plugs
  • Wires
  • Cap
  • Fuel Filter
  • Fuel Pump
  • O2 Sensor
  • Injectors
  • Had fuel rail leak, now fixed
  • Had Lower intake leak, now fixed
  • Had a spare ICM and coil (used, I know it was working because it was on the engine I removed from car) replaced them both.
  • Coolant temp sensor
  • MAF (used)
  • ECM (remanufactured)
  • Chip (stock)
After changing engine out I drove this car maybe 2 mths w/ no problems then all of a sudden it started to sputter a little. It got worse and worse till finally one day car died..... started it up and it ran w/ no problem, died again a few minutes later, started it up and ran fine again.
Well finally I started changing stuff and you can see how much I have changed above.
Tonite just finished w/ the injectors and fuel rail and intake stuff. Car ran ok 1st time around block. Came back to bleed brakes (new calipers and drum brake cylinders) went to drive again and started the sputtering.
I noticed was kinda low on gas so I went to fill it up and damn!!!! It ran better like nothing was wrong. Drove about 15 minutes and sputtered again but not as bad, so I shut car off, crank it up while still rolling and wham, its not sputtering.
I stoped to pull of gas cap cause I am now thinking the tank must not be getting air. Nope no diff. So I can only think that my fuel line is clogged.
Long story long, could this be it, any more suggestions? I have no hair but if I did I would probably pull it out! This car did sit up a while before I bought it and it sat maybe 2 mths after the problems started.
Gurus Talk to me!!!!!
Old Sep 5, 2009 | 02:42 AM
topfile's Avatar
Re: <1/2 Tank, Sputters, >1/2 or full Run Much better Whats Going On! Story Inside
Certainly Not a Guru, but I'd put a bottle of Sea Foam in it on my next fill up.
Old Sep 5, 2009 | 08:26 PM
irocturn&burn's Avatar
Car: 91 Z28
Engine: aluminum block 5.3
Axle/Gears: 4th gen rear 4:10 welded
is your check engine light on? if it is, did you pull any codes out
Old Sep 5, 2009 | 09:30 PM
Slowridr's Avatar
Yes sometimes a 23 and sometimes 13. I tink those are MAT and O2 sensors. Its got a new O2 on it. Is it possible that the o2 is a faulty one. Is there a way to check it.
Old Sep 6, 2009 | 12:13 AM
Car: 91 Z28
the o2 code probably set due to a lean exhaust from running out of fuel at times.
i would first check that you have 35 to 37psi of fuel pressure if you do, You can try driving the vehicle when you know it will sputter, then bypass the fuel pressure regulator. that will take your fuel pressure from about 35psi up to 50psi. and if that cures the sputter it is most likely a bad pump or regulator assuming your fuel filter is good.
Old Sep 6, 2009 | 12:19 AM
Car: 91 Z28
if you think all of that stuff is ok or checks good try testing and adjusting your throttle position sensor. it can set an o2 code(sounds goofy,i know) and cause a sputter or make it fall right on its face when you nail on it.
Old Sep 6, 2009 | 12:33 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
did you have the distributor gear checked and pickup coil also module.
  • Plugs
  • Wires
  • Cap
  • Fuel Filter
  • Fuel Pump
  • O2 Sensor
  • Injectors
  • MAF (used)
  • Chip (stock)
Old Sep 6, 2009 | 09:04 PM
Slowridr's Avatar
Keep it coming fellows I need to get this figured out. I drove this car for about 2 hrs today and it didnt sputter once. I must admit I didnt drive it hard, I did some freeway driving (10 mi worth at about 65-75 mph) also a lot of parkways and stop and go. Usually stop and go would give me problems when the sputtering was at its worst. Scared to death it was going to quit on me today but never sputtered once! The only thing I did was put 2 bottles of fuel injector cleaner in with one tank of preminum gas.
Please dont stop making suggestions though.
Old Sep 6, 2009 | 10:10 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
there is a hose that sits between the sender and the pump, they tend to perforate and leak.
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
Kaweh
Aug 9, 2015 02:54 PM
