Is there any performance benefit to EGR?
Old Sep 5, 2009 | 10:20 PM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
I don't think so, but I want to hear what you guys have to say about it.
Does it take power away from the motor?
This is completely theoretical, I just want opinions and facts, not smog laws.
Old Sep 6, 2009 | 01:05 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Is there any performance benefit to EGR?
I doesn't have any effect on performance, as its not in use at idle or at WOT - its only used under light throttle/cruise conditions. It's known to help fuel economy noticeably - meaning that most people who disable it LOSE fuel mileage and gain nothing in return. If it works fine, leave it alone. If it doesn't work, fix it. You gain nothing from removing it.
Old Sep 6, 2009 | 04:16 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
It also helps keep the cylinder temperatures lower, which keeps the engine from knocking or pinging.
The biggest knock against it is because its dirty exhaust gasses, the carbon gets into the intake passages and makes them dirty too.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
sailtexas186548
Feb 17, 2017 03:07 PM
92firebirdguy
Sep 1, 2016 07:53 AM
Kenwood
Sep 11, 2015 12:50 PM
rjcme
Sep 5, 2015 01:23 PM
