Trouble Code 23 -91 RS Camaro 305-
Old Sep 16, 2009 | 11:03 AM
Yor's Avatar
Yor
Car: 1984 15th Ann. T/A
Engine: 350 Goodwrench
Transmission: T5 (Not factory, possibly rebuilt)
Hey guys, haven't posted in a while. I finally got my first Camaro, it's a 1991 Camaro RS with the 305 TBI and a 700R4 Transmission. Got it for like 450 bucks and it's pretty solid, it just needs a tuneup, a brake line and some paint.
Anyways, while I just changed the air filter, air breather, manifold temp sensor, rotor, cap, plugs and wires (Except the rear ones on each side, can't reach them myself. ><) I siphoned out the bad gas that was in it, added some new gas and some gas treatment/injector cleaners, cleaned out the throttle body and replaced the serp belt. For some reason though, Trouble Code 23 flashes even though I changed my manifold air temp sensor. Also, it seems like when I first start it up the car runs fairly well, but once it's warmed up if I put my foot on the accelerator up to like 2k rpms, the engine starts to chug, bogs down, then gets back up to standard idle rpms.
I haven't changed the fuel filter yet which is next on my list, but I'm still unsure why the engine keeps doing that and why I have trouble code 23.
Trouble code 23: Manifold Air Temp. Sensor
Defective Sensor
Defective ECM
Short in circuit or wiring
That's a few of the things that are listed in my troubleshooting manual for Code 23, does anyone have any suggestions?
Old Sep 18, 2009 | 11:46 PM
Richwiz1's Avatar
Re: Trouble Code 23 -91 RS Camaro 305-
check what book says also make sure plug wire on right and tight.My guess you bought a bad sensor its happened to me.
Frozer!!!
Jan 19, 2024 04:55 PM
apie2546
Aug 10, 2015 05:43 PM
antares57
Aug 6, 2015 07:47 AM
