When to upgrade the stock fuel pump
Old Sep 22, 2009 | 11:55 PM
cheppibear's Avatar
Car: 1984 T/A
Engine: Chevrolet 355
Transmission: Borg Warner
Anyone know the volume (GPH) of the 1984 LG4 stock fuel pump and when it becomes a performance obstacle?
I have a 355 making around 325 HP and need to know if I should upgrade.
If yes what should we do with the fuel return line outlet (coming out of the stock pump - the one not going to the carb) if the performance pumps available do not have that outlet?
Currently running an EDEL 650 cfm carb.
Old Sep 23, 2009 | 09:59 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: When to upgrade the stock fuel pump
The in-tank electric pump is known good to 308 crank HP as proven on an engine dyno. If you're running that, then don't bother with another pump on the block, just get a return-style fuel pressure regulator set to about 5.5 psi. If the pump in the tank fails, having one on the block won't save you, since it can't pull fuel through a failed electric pump in the tank.
Old Sep 23, 2009 | 10:45 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If you don't have an in-tank pump, which you may not (at least my 85 IROC doesn't have one), you might consider the following. According to five7kid, the Carter M6626 is a good choice for the mechanical. It has the return line, and is rated for 120 GPH.
BTW, I'm running an off-the-shelf pump on my 350/330 with no noticeable problems.
JamesC
Old Sep 23, 2009 | 10:47 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I was not aware of that pump. Thank you JamesC.
Old Sep 23, 2009 | 08:00 PM
cheppibear's Avatar
Car: 1984 T/A
Thanks - Good to know about the stock pump and also what part# would offer an alternative solution that would work perfectly for 30 bucks.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
theshackle
Mar 5, 2017 06:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
