Alternator Adjusting Bracket
Old Sep 30, 2009 | 11:17 PM
85TransAmDude's Avatar
Car: 1985 Firebird Trans Am.
Engine: 305 H.O. 4bbl
Transmission: 700R4.. I think
Axle/Gears: Not Sure, 3.73?
Ok, so my belt was squeaking when I would start up the car cold sometimes, so I figured I would pull the belt off, clean it up and put it back on and see how that would be. I loosened the bolt that holds the alternator onto the adjusting bracket and slid it back, but when I did the metal just started breaking off, basically rusted off, I have a pic below of what Im talking about. Now I went to my local GM dealership and they said this part is no longer available. Is there any way I can get my hands on another one?
Thanks, Trent
Here is the pic...
Old Sep 30, 2009 | 11:28 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Alternator Adjusting Bracket
Autozone should have one on the shelf in chrome that will replace that - looks just like the one I just bought - I want to think it was under $25 maybe? Attaching points for that part of it (the top part are the water pump and the intake, right?
Looks like: http://www.summitracing.com/parts/MRG-5171/
In fact, I think this is the exact same one that Autozone carries. The summit pic shows the top part (the part that broke), and the bottom part (which you should have under there.
Old Sep 30, 2009 | 11:33 PM
Looks very similar, however I don't have an autozone here in NL, Canada, there is an autoparts network that i checked out that sells AC Delco parts and they cant get it either. Now ive checked Ebay and they sell the 2 parts that you mentioned for something like $100 which sounds a bit steep if you ask me.
Old Sep 30, 2009 | 11:56 PM
Car: 1992 RS
Engine: Carbed 350
here ya go:
http://cgi.ebay.com/ebaymotors/Chrom...Q5fAccessories
may be others, this was 1st one I found that stated worldwide shipping.
search ebay for "chevy alternator bracket" - then look for pics like that, then check ships to for worldwide
Here's another:
http://cgi.ebay.com/ebaymotors/ALTER...Q5fAccessories
and another:
http://cgi.ebay.com/ebaymotors/CHROM...Q5fAccessories
Old Oct 1, 2009 | 07:32 AM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
order online at autozone. dude
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
Eric-86sc
Exterior Parts for Sale
Nov 16, 2015 10:20 AM
1Aauto
Sponsored Vendors
Sep 8, 2015 11:14 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
