which donar vehicle for tpi distributor
Old Oct 2, 2009 | 07:20 PM
scoates's Avatar
Anyone know which donor vehicles have an hei with the rollercam gear. i have an 87 vette that i am trying to convert back to tpi. The previous owner put a carb on it.
Old Oct 4, 2009 | 11:18 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: which donar vehicle for tpi distributor
Did he change the distributor?
'87 is the transition year. Roller cam in engine, but big cap distributor. Very rare distributor.
Early model TPI setup on this engine. Not the same as '88 and up.
Best bet is to just get a melonized gear and forget about it.
Old Oct 4, 2009 | 11:30 AM
scoates's Avatar
Yes the distributor was changed. i just picked up a small cap hei an coil off a 91 caprice. The conversion looks pretty easy.
Old Oct 4, 2009 | 11:51 AM
Engine: 350 4BBL
Let us know if it works. If so people with big cap non-vacuum advance dizzys can change to small cap.
It depends on the voltage levels coming off of the module going to the ECM.
Caspar
Jun 19, 2016 11:19 PM
stalkier
Dec 6, 2015 11:25 PM
g.l.mos
Aug 22, 2015 12:02 AM
Out-Cast
Aug 17, 2015 10:57 AM
Sanjay
Aug 12, 2015 03:41 PM
