How to adjust idle by turning distributor?????
Old Oct 5, 2009 | 02:06 PM
Chevycam90's Avatar
Car: 1990 Chevy Camaro
Engine: 3.1 V6
Transmission: 700 R4
Went for PA vech inspection and the vech failed because the idle is to high the garage said i can turn the idle down by turning the distributor? Has anyone done this or is there other ways? I have new plugs and wires no vacumun leaks no exhaust leaks. Thanks in advance for any help.
Old Oct 5, 2009 | 02:11 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: How to adjust idle by turning distributor?????
This is sort of true, but doing this may cause you to fail the emissions test. First look for vacuum leaks and such.
Old Oct 5, 2009 | 02:34 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
What is your idle rpm?
Moving the distributor will change you base timing, not a great idea unless it's set incorrectly. There may be an adjusment on the TB to close the blade some, but the idle is controlled by the IAC.
If it's excessively high as Atilla said check for a vacuum leak.
Old Oct 5, 2009 | 04:53 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
IAC passages may be carboned up not allowing IAC to seat correctly.
If it hasn't been done recently , take TB off disassemble and clean.Then reset idle
See
http://www.corvetteactioncenter.com/...and+Idle+Speed
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86IROC112
Aug 17, 2015 02:00 PM
