any clue how much I have increased horsepower?
Old Oct 6, 2009 | 09:31 AM
Dragula85's Avatar
Car: 1985 Pontiac Trans-Am WS6
Engine: 305 5.0 TPI bored over 30
I have an 85 T/A 5.0 305 TPI bored over 30, just put hooker shorty headers on it, 19lb injectors and mass air, port and polished heads (oem otherwise) and a cold air intake K&N filter..any idea how many horsies I have added to the original 215 that came stock?
Old Oct 6, 2009 | 03:19 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
It should have come with 19 lb/hr injectors.
The other things you did probably added about 5-10%, mostly from the headers, so probably in the 225-235 range now.
Old Oct 6, 2009 | 04:00 PM
CamKid1992's Avatar
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
Re: any clue how much I have increased horsepower?
just to give you an idea i put the stealth ram setup witch i like alot on my car and the hookers with 30lbs and im right at 260 with a good tune.
RedLeader289
May 28, 2019 01:47 PM
92camaro350cci
Oct 14, 2015 09:29 AM
gord327
Oct 3, 2015 01:25 PM
hartsmike
Oct 2, 2015 07:11 AM
